Originally Posted by jcouch
Which type of rear end does my 1998 SR5 4x4 4-runner have...My mechanic just determined both rear axles are bent on my 1998 4runner. This was detected when the rear end started making abnormal noise due the bearings popping out. It was suggested I should replace the entire rear end. However, the Toyota dealership informed me there are (3) different types of rear ends for this model and I need to know the "ratio" to determine which type...in order to determine the ratio, the rear end woudl need to be dis-assembled in order to count the gear teeth. Is there any way of determining which rear end I have short of disassembling the existing rear end?????
Both axle shafts are bent? seems kind of strange. Is the axle housing bent?
Unless an exact determination of the whole problem and it's cause can found,
I think I would want to replace the entire rear axle.
The ratio is part of the axle code on the VIN plate on the doorjamb.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
