The 4wd indicator lights when the ADD front axle locks and the t-case is in 4wd.
The front axle lock and unlock is done using Vacuum valves.
You could have a bad valve or vacuum line.
Start by getting underneath and checking the basic line connections.
And adding auto or manual hubs will not help with this problem.
 SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
