If the shifter was rocking around in all gears as you varied the engine rpm then I would guess a bad motor mount. It isn't the shifting fork unless you have it badly adjusted and there is no play. If it is happening only in 5th gear then the gear set itself is maladjusted, chipped, or worn. Again here, likely not the synchronizer. More likely a chipped gear.
