Originally Posted by Pawel062
sounds like you have my 07 camry v6 before they did the ecu reflash. my father saw this response and suggest 1 you check your air filter to make sure it ain't clogged up 2 you disconnect your battery for a minute and reconnect it so your computer will reprogram itself and 3 if your putting in low octane then put in the high octane stuff. these cars work best with the highest octane. i use sunoco's ultra 93 and used to use the 94 when they had it.
edit: my dad also said to check the vacuum hoses and you should open up the air cleaner and see if there is anything there. you said u were at the delership for them to install the grill so they might of forgot something. also crazy as it sounds but the dealership might have done something. someone i know usually went to this nissan dealership in my area and they always did something so he would come back. with this economy, everything is possible.
Thanks for the suggestions, but I'm not sure I want to do anything to the car while it's still under warranty. I will leave it to the dealership.
