1500 plus labour? A 4AGZE would give you around around 130 -160 HP stock, depending on which year you get. But the motor alone would probably be around that price. A Redtop 4AGE would be 130 but no supercharger and its not as stout, cheaper though. In either case you could use that tranny, different harness and ecu though. A less expensive and less exciting swap would be a 7AFE, its basically the same motor as you have now, but 0.2L larger. Not sure about the ecu and harness on that one though.
