Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Ignition Lock Cylinder 5th gen
View Single Post
Old 03-09-2009, 10:13 PM   #9 (permalink)
Rick89GTS
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
The freshly cut key will be sharper and not mate perfectly with the worn ignition switch. You could carefully file down some of the edges and keep test fitting it until it turns.
Another option is to get a used complete ignition and door set from a wrecked Celica, but that is time consuming and labour intensive.
If the locksmith is going to install new tumblers, it may be worth the $100 or so.
Sorry, I don't have an easy solution on this one...
Rick89GTS is offline   Reply With Quote
