FSM says to use NGL-2 Lithium Complex grease with Molybdenum for the drive shaft slip joint.
The spiders (u-joints) get regular NGL-2 Lithium Complex.
Ken had a good post in 2004:
"Lithium is the base material in the grease, moly is an additive in the grease, and synthetic tells about the type of oil held in the base.
The base is the thickener. Lithium or lithium complex is probably the most popular grease base material. The base is something like a sponge. It holds oil in its pores, and the oil does the lubricating. The oil can be conventional or synthetic. Molybdenum disulfide is a dark gray powder that is very hard and very slippery. It is one possible additive to grease, and moly is excellent for slow moving, heavily loaded points...I use moly-additized grease on the sliding spline on the driveshaft.
So, grease can be lithium base, contain synthetic or conventional oil, with or without moly.
Top quality lithium base moly grease is fine everywhere. Less than top quality moly can contain abrasive particles that can damage needle, ball, or roller bearings."
