2007 taillight replacement help needed! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4th Generation (2003-2009)
4th Generation (2003-2009) Discussion area for the fourth generation Toyota 4Runner.
Old 05-20-2010, 07:37 PM   #1 (permalink)
2007 4runner
View curacao30's Photo Gallery
Help!
I had to replace my passenger-side taillight due to an "incident" with a parking lot post. I ordered a new assembly and have just tried to hook it up and here's my issue:
The turn signal and reverse lights don't work in the new assembly. The LED brake lights work, so I know there's power going to it and the connections appear fine. Also the drivers side is working just fine.
I tried reconnecting the old (still working, though cracked) taillight, and it has now developed the same issue! 5 mins prior it had been fine!
I have double-checked all my connection points, the bulbs, and the fuse, to no avail.
Please help with any suggestions!
Thanks!!!!
curacao30 is offline   Reply With Quote
Old 05-22-2010, 01:28 PM   #2 (permalink)
View sunbleach4x4's Photo Gallery
The only thing i could suggest is check youve earthed the assembly via external wire to bolt hole in the frame.Also ensure the common earth wire inside the light is connected to all three light globe earths. Failing that plug the working light into the problem side to rule out the connector and wiring. let us know if this makes a difference. I had a bad earth with similar symptoms which resulted in wierd light operations . I found out that my taillights were working only when indicating ...ie the tailights were earthing back through indicator circut wiring . hope this helps sounds like an earth problem.also check for rust around the earth lug and clean up
sunbleach4x4 is offline   Reply With Quote
Old 05-23-2010, 07:55 AM   #3 (permalink)
2007 4runner
Thanks for responding -- I messed around with it yesterday and figured out the problem -- a simple (read: stupid) one!
The center connection point wasn't fully rotated into position so wasn't providing a connection to the reverse and turn signal lights.
I guess I was being a little too cautious about putting enough pressure on it.
-- A.J.
Old 05-23-2010, 08:09 AM   #4 (permalink)
Australia
haha easily done hey ? its a good one to remember tho as bad earths play some really funny tricks... AJ too!
