How did things work out? Brake transmission shift interlock solenoid (BTSI is the general term, some manufacturers use different names)... Releases the shifter lock when the brake is applied, it's usually right in the console with the shifter or can be remotely mounted by cable operation. Might be worth a look in there to see if it's moving, make sure it's plugged in and getting power/ground when brake is applied. I know these posts are a bit old, so hopefully things got fixed for you.
- 2005 Tacoma Access Cab 4WD TRD Off Road, Speedway blue, Magnaflow cat-back, 265/75R16 Hankook Dynapro ATM, 55000km. *SOLD, she will be missed, but someday replaced*
- 2007 4Runner 4WD Sport V8, Silver, all stock, 40000km.
- 2010 GMC Sierra SLE 2500HD 4WD Duramax diesel
