how do i remove the roof rack from my 05 4runner sport the right way? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4th Generation (2003-2009)
4th Generation (2003-2009) Discussion area for the fourth generation Toyota 4Runner.
Old 06-10-2010, 11:10 PM   #1 (permalink)
View 05toyo4runner's Photo Gallery
05toyo4runner is offline   Reply With Quote
Old 07-13-2010, 05:23 PM   #2 (permalink)
View CJ3Flyr's Photo Gallery
I followed the intructions below (from hemitruk at another forum). Worked like a charm, I have since put the rack back on and actually used it:-)
"Pretty easy to remove.Pop off covers on ends with flat blade screw driver gently.Then theres 2 torx head screws on each corner.remove all 4 corners and have someone help you remove rack.You will also need brackets and covers to put in place of rack.You will need 8ea.part#90119-08C47 bolts with washers 4ea. part# 63185-42020 brackets and 4ea. part#75596-02020 covers.Just bolt brackets inplace of roof rack and pop covers on.Picture is of a rav 4 roof with the brackets installed.cover just needs to be poped on.$runner is the same except the cover looks a little diferent.My runner is a 08 but 06 should be the same. "
I stole and reposted the pic too
Chris
'07 SR5, V6, 4WD, Sunroof, JBL upgraded stereo, Toyota accessory Sirius kit, Swaybar Bushing upgrade, AirLift1000, Cyclone pre-cleaner
CJ3Flyr is offline   Reply With Quote
