Grinding Noise and Sensation - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4th Generation (2003-2009)
4th Generation (2003-2009) Discussion area for the fourth generation Toyota 4Runner.
Old 06-25-2010, 04:24 PM   #1 (permalink)
View benh43's Photo Gallery
I had new front brake pads installed and the rotors turned on my 04 4runner about 3 years ago. About 1 year later i had the rotors turned again but the pads were still good, the rotors were turned to the minimum. I had my brakes inspected by a mechanic about 4 months ago and ended replacing the rear pads and turning the rear rotors but the mechanic told me the front was fine.
For about a month now I've been getting a grinding noise coming from the front end when braking at slower speeds. I assumed it was metal on metal and I needed to replace the front brakes and rotors. I just took off my front wheels and checked the pads and the pads look great, I compared them to new pads and they have a ton of material left on them.
Any idea what could be causing the grinding noise? Only happens while braking.
benh43 is offline   Reply With Quote
Old 06-25-2010, 09:19 PM   #2 (permalink)
Gameroom cash: $207700
View kball's Photo Gallery
When you checked the pads did you look at both the inside and outside pads? They can wear at different rates. Sometimes brakes can sound bad depending on the type of pad and rotor but still be fine. Have you gone offroading lately? Maybe some gravel is trapped in between the caliper and rotor.
kball is offline   Reply With Quote
Old 06-25-2010, 10:47 PM   #3 (permalink)
heartdisease's Avatar
Gameroom cash: $116470
View heartdisease's Photo Gallery
I have noticed differences in the brands of pad. I like oem personally the aftermarket stuff changes things. This is in general I don't have a 4runner.
heartdisease is online now   Reply With Quote
