If the 2003 has the same design as the 3rd generation, the brief clicking you hear at startup is part of the diagnostics/maintenance of the ABS system.
The ECU and relays that control the running of the ABS motor, pulses the motor briefly at startup (and generates the clicking sound).. good maintenance to ensure the motor, brushes, and ABS seals aren't sitting in the same position for long periods of time, since the ABS is rarely activated..
As said above, it everything is working, don't be concerned about it.
