2003 a/c problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4th Generation (2003-2009)
4th Generation (2003-2009) Discussion area for the fourth generation Toyota 4Runner.
Old 08-28-2010, 05:45 PM   #1 (permalink)
View Tex-Tac's Photo Gallery
2003 a/c problem
Owner of a 2003 4Runner, recently started to encounter problems with my a/c. The panel a/c indicator light starts to flash and the manual says as follows:
"If the "A/C" button indicator flashes, there is a problem in the air conditioning system and the air conditioning automatically shuts off. If this happens, take your vehicle to a Toyota dealer for service".
This is exactly what is happening to my 2003 4Runner, but, before I do take it to the dealer, I just wanted to know if anyone else here has experienced this problem before and what was done about it. Were you able to solve it yourself? Did you take it to the dealer? What did they tell you?
If it is something that I can solve/correct myself I am listening.
Thanks eveyone for your help.
Tex-Tac is offline   Reply With Quote
Old 08-30-2010, 10:55 PM   #2 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
I'm going by memory here, but when this happened to my brother Celica it was the relay. Hopefully that is your issue as that is probably the most least expensive part to replace/repair.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 09-03-2010, 08:16 PM   #3 (permalink)
View outsider60's Photo Gallery
Does the a/c blow cold when on? If so, check the a/c clutch for engagement and if it's slipping when on.
outsider60 is offline   Reply With Quote
Old 09-06-2010, 09:00 PM   #4 (permalink)
2002 Camry
if you turn on the A/C, normally the A/C clutch engages and causes resistance to the belt, and you can feel and hear it engage. If it's electrical, the A/C clutch won't even engage and you won't feel or hear anything happening.
That might be a good starting point to troubleshoot it.
