artwall,
That code relates to a crankshaft position sensor signal. It you have a check engine light come it disables the VSC and Trac system. Until you get that sensor fixed the VSC and the TRAC system will be inop. So whenever you have a check engine light come on that is what you will see. Even though you cancel the check engine light the fault still exists and the VSC/ TRAC light will come back on. That is a sure way to tell that something is wrong.
