2004 4Runner Ignition Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4th Generation (2003-2009)
4th Generation (2003-2009) Discussion area for the fourth generation Toyota 4Runner.
Old 10-17-2011, 08:47 AM   #1 (permalink)
View Winter Camper's Photo Gallery
Unhappy 2004 4Runner Ignition Problem
Good morning. I am new to this forum. I am here for a reason. I'm looking for suggestions on what my problem might be (easy now). I have a 2004 4Runner SR5, about 65K miles, that has an intermitent ignition problem. On occasion, usually after driving the car for an hour or more, I will stop and turn off the engine. When I go to restart the engine I get nothing. No power to the starter, although the dash is lit up like usual, when turning the key to engage the starter I get nothing. No clicks, no nothing. Last time this occurred I has driven for about 2 hours on the Interstate and stopped at a rest area. Turned off the engine and when I came back to start it again. Nothing. I have had this happen for about 1-2 years, usually occurring more often in the summer. Maybe happened half dozen time over the period, always at an inopportune time. Usually the car would start after some period of time, ranging from 15 minutes to 10 hours or so later, seemingly while it has had time to cool down. My mechanic installed a test light that he wired to the starter (in front of the solenoid?) so that when the igition was engaged I had a little indicator light that came on in that I could see in the cabin, indicating that I was getting power to the starter. When the condition occurs, the test light does not come on in the cabin, which we think indicates that the cause of the condition is not the starter or solenoid itself, but something further up between the battery and the starter. I am going to replace the starter relay to see if that makes a difference. Won't be able to tell if that was the cause until the car doesn't start again. If I never have the problem again, that must be it. Anybody have any other ideas before I start replacing stuff? Does the anti-theft system have anything to do with it? Intermitent is tough to figure out. It never manifests itself at the dealers or at my regular mechanics. Anybody have any similar experience?
Winter Camper is offline   Reply With Quote
Old 10-17-2011, 09:38 AM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $916327
iTrader Score: 59 reviews
to TN
I moved your question thread to the proper forum. You should find advise here!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
The Following User Says Thank You to eyeball96 For This Useful Post:
Winter Camper (10-17-2011)
Old 10-17-2011, 10:08 AM   #3 (permalink)
To which forum should I have posted this question?
Old 10-17-2011, 10:14 AM   #4 (permalink)
Super Moderator
eyeball96's Avatar
This one, that I moved it to.
98 Honda CRV
08 GMC Crew
Old 10-17-2011, 11:43 AM   #5 (permalink)
Thanks - I got the picture.
Old 10-17-2011, 11:59 AM   #6 (permalink)
Super Moderator
eyeball96's Avatar
Your welcome! Never a problem. Help is what we're here for.
98 Honda CRV
08 GMC Crew
Old 10-18-2011, 04:49 AM   #7 (permalink)
Gameroom cash: $425365
View jetwhine's Photo Gallery
Winter Camper,
I would not replace the starter at this time, as with no light on means no power and that power comes through the ignition key switch. It is not uncommon for these key switches to go bad. I have seen several so far.
jetwhine is offline   Reply With Quote
Old 10-18-2011, 11:59 AM   #8 (permalink)
Thanks Jetwhine. I'm going to replace the ignition relay tomorrow and wait and see what happens before I replace anything else. Have you ever seen where the ignition key switch problem was intermitent? I still have the idea that this is temperature related. What does it cost to change the ignition key switch? Does a dealer have to perform some special magic to make it work? Appreciate the feedback.
Old 11-05-2011, 05:20 PM   #9 (permalink)
Winter Camper,
Yes that is how the switch starts to fail, they start by being intermittent then fail all together. The installation is not too hard. No magic involved, the only thing is your key for the ignition will be different than the one for the door lock. But I sure a lock smith can take care of that problem for you.
