Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Ignition Lock Cylinder 5th gen
View Single Post
Old 03-10-2009, 05:46 PM   #11 (permalink)
franchise23cc
View franchise23cc's Photo Gallery
OK now before I pulled the cylinder out I tried the key some more, I can now get it to turn just fine but only when i use a screwdriver or something similar to bump the key as i turn it and it will go just fine after the bump, Is it possible it'll just take some time to wear the key in this way or should I plan on getting the cylinder out soon. Also where is the pin I'd need to push in to remove the cylinder while the key is in "acc"? Thanks alot
franchise23cc is offline   Reply With Quote
