Originally Posted by jughead0691
Hi there,
I have a 1990 ST184 Celica coupe that has suddenly developed a excessive fuel consumption problem. I went from 600km per tank to 380km per tank. I have replace the spark plugs and leads, Air filter and oxygen sensor. I have checked and adjusted the ignition timing. The questions I have are as follow:
1. Would a faulty coolant temp sensor (Not the gauge sensor) be the problem & if so how do you test it.
2. Fuel injector rail pressure regulator be at fault
3. Faulty injectors (I don't think this is the problem - I have never seen all four injectors fail at the same time)
Any help would be greatly appreciated.
Many Thanks,
Jughead
I think you misspelled Australia on your sign in tab.
