Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Replace glass in driver side mirror
View Single Post
Old 03-16-2009, 11:39 PM   #12 (permalink)
Danno_MN
Old-phart newb w/clue
View Danno_MN's Photo Gallery
Talking
Originally Posted by BamZipPow View Post
I was responding to Danno's post about using hot water...
Well, if the screw releases the part from the electrical parts, the hot water should do fine. Mostly, I don't soak electrical parts unless I can certify them dry afterward (like open switches) - and those, mostly in contact cleaner. Mostly, I don't hit electric motors/relays with a heat gun, either. They're no good once you let the smoke out of 'em.
I'm not really as dumb as I look. Really. Unless we're playin' poker - in which case, you should think I'm even dumber than that.
Danno, who once actually filled an inside straight. Once. Was hopin' for a pair, 'cause I didn't believe his flush.
Danno_MN is offline   Reply With Quote
