2010 4runner part time 4 wheel drive question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 5th Generation (2010+)
5th Generation (2010+) Discussion area for the fifth generation Toyota 4Runner.
Old 05-25-2010, 08:08 PM   #1 (permalink)
View tim.powerbook's Photo Gallery
So I have a new 2010 4runner with part time 4 wheel drive. It says in the manual to drive 10 miles a month in 4 wheel drive. It doesn't say anything about dry pavement, but from what I've read online, driving in 4H on dry pavement will tear it up. Is this true for the new 4runner?
Smarter than the average bear!
tim.powerbook is offline   Reply With Quote
Old 09-02-2010, 08:50 PM   #2 (permalink)
View scarney1988's Photo Gallery
Do not engage 4 wheel drive on pavement. Try to find some type of off road area... (Dirt road, field, unpaved stone parking lot, etc...). Much better and will prevent anything from getting stuck internally.
good luck
Sean
Toyota Tech
scarney1988 is offline   Reply With Quote
Old 11-30-2010, 03:40 PM   #3 (permalink)
Gameroom cash: $196740
View Yazon's Photo Gallery
Any explanation for this procedure? I've never heard of such requirements before and wonder why this is the case. I definitely have long stretches of time when 4WD would not be engaged ( spring-fall).
I don't have 4runner right now, but was thinking about getting one in the future.
Yazon is offline   Reply With Quote
Old 01-03-2011, 12:05 PM   #4 (permalink)
View tommytuttle's Photo Gallery
probably suggested to keep the shafts all lubed up. I had an 81 with a seized front driveshaft from a lack of grease, too much dirt and not engaging it enough.
tommytuttle is offline   Reply With Quote
Old 04-26-2011, 09:38 PM   #5 (permalink)
so not all 4x4s say this in the manual? i'm still loving the 4runner, and have used the 4 wheel drive, but not 10 miles a month though
Old 05-01-2011, 12:24 AM   #6 (permalink)
View xxJDxx's Photo Gallery
It should be fine to use on pavement so long as you only use it on a straight stretch of road. You just cant turn when in 4x4 on a paved surface...
xxJDxx is offline   Reply With Quote
Old 08-03-2011, 02:02 AM   #7 (permalink)
LTD
all back a da bus & s**t
View LTD's Photo Gallery
I agree wouldn't drive across country like that but these rigs have much tighter tollerances than the old don't drive on pavemeant period or you'll lock up and break things days. As long as you don't have different sized tires on the front and rear or a locker up front (won't want to turn) it shouldn't do any harm. You still wouldn't want to crank the wheel one way or the other but everyday driving would be fine just don't parallel park or pull a U-turn while engaged.
LTD is offline   Reply With Quote
