2003-2009
TOYOTA 4RUNNER GPS NAVIGATION DVD RADIO
CURRENT PROMOTIONAL
HOLIDAY SALE $400....
please make sure your car does NOT have premium sound or factory navigation
DVD. GPS NAVIGATION. CD PLAYER. IPOD CONNECTION.BLUE-TOOTH.
EVERYTHING NEEDED TO INSTALL UNIT IS INCLUDED
FREE MAPS AND GPS ANTENNA....
2 DIN 6.2" LCD Touch Screen Car DVD Player, GPS, Bluetooth, iPod and More!
Specifices:
- Standard Double Din Mounting Size OEM FITMENT
- UI Language: English
- Car Audio & Video System
- Screen Size: 6.2 Inch
- Touch Screen Function
- Resolution: Digital 800x480 touch Screen
- Control Panel Night Illumination Function
- Compatible Format: MP4/DIVX5.0/DVD/VCD/MP3/CD/CD-RW/JPEG
- DVD OSD Language: English
- Audio/ Subtitle Language: English
- Support Bluetooth
- Built-in Microphone in the control panel
- Built-In USB Port/SD Slot
- TV system: PAL/NTSC
- Built-in Radio Tuner (30 Preset Stations)
FM (3*6)87.5-108MHz Increment 0.05MHz
AM (2*6)522-1620KHz Increment: 9 KHz
- Built-In RDS Radio Receiver Function
- External GPS Box
- Steering Wheel Control Function
- Built in amplifier FR/FL/RR/RL 4-Channel Audio Output
- Two Channel Video Output / One Channel Video Input /AUX Audio R/L Input (RCA)
- Support Back sight video Input
- 4×45W Surround Stereo
- Effect Compensation: POP ROCK CLASS
- Image Brightness /Contrast/ Color /Saturation adjustable
- Auto-memory Function
- Power Supply: DC 12V
- Max Working Current: 10A
GPS Features:
Operation system: Windows CE 5.0 OR 6.0
Processor: SAMSUNG High performance processor S3C2440A-40, Max.main frequency 600MHZ.
EMS Memory :64MB SDRAM
Storage device: 128MB NAND FLASH,Support SD Card.
Display output : CVBS+S-VIDEO output. (Resolution:480*234) or simulation RGB output .
Audio output: Stereo output of CD tone.
GPS specification: Adopt SiRF STAR III 20 channel and excessive high sensitivity GPS receiving module REB-3310, Orientation sensitivity reach
-159dBm, Orientation presicion<10M,Orientation time of cold boot is 42S,Orientation time of warm boot is 35S,Orientation time of hot boot is 1S. Power specification: Connect car power DC12V,Current<500mA;Max power Consumption:4.5W(12V/360mA),Normal power consumption 3W(12V/250mA).
System parameters:
Working voltage DC 11V~14V
Working current MAX 15A
Standby current <25 mA
Video system Automatic PAL or NTSC
Radio parameters:
FM/ AM Frequency FM:87.5MHz~108MHz; AM:522KHz~1620KHz
Tune method PLL frequency complex tune
Display method TFT Graphical User Interface OSD
Storage quantity FM radio :18 channels, AM radio: 12 channels
Search method Automatic/manual
DVD parameters:
Video output range 1+10.2Vp-p (75)
Disc spec Diameter 12cm disc
Compatible disc DVD(NON REGION 1 )/VCD/CD/MP3/WMA/JPEG/MPEG4
Amplifier parameters:
Testing voltage 13.8 V
Maximum power output : 4×45W
Speaker impedance 8Ω (4-8 acceptable)
Audio parameters :
Track imbalance degree ≤2dB
Segregative degree ≥45db
Frequency response: 20Hz~20KHz(±3dB)
Volume adjustment :
Low 100HZ±7dB
Medium 1KHZ±7dB
High 10KHZ±7dB
Accessories:
- 1×User's Manual
- 1×Remote Controller (Battery inside)
- 1×Power Cable
- 1×USB Cable
- 1×SD CARD with the GPS MAP
Other things to know:
*-Advance Picture in Picture screen. Just like your TV (PIP) you can view two screen at once. Watch you movies and have a little screen for your Navi map. Best of both world with this unit.
*-Dual Zone, Can listen to music while in GPS mode and the music will stop and the Navi will speak the direction.
*-iPod ready- Just plug your iPod or iPhone to the adapter and pick you music list straight from the screen.
*- Bluetooth
