Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 3sge swap into 89 celica
View Single Post
Old 03-31-2009, 12:36 PM   #2 (permalink)
Rick89GTS
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Yes, but you need the 3SGE motor, ECU, wiring harness and any engine ancillaries.
The motor mounts line up (all "S" series engines do) just be advised you may also have to get the exhaust manifold and downpipes, modify the starter position and change CV axles. Not sure if the clutch/flywheel/pressure plate are swappable though.
IMO, not worth the trouble to go from 115 hp to 135 hp. with all the parts, time and labour, you could just find a decent GT-S and be done with it.
Rick89GTS is offline   Reply With Quote
