00 Sienna - Vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 08-30-2003, 04:46 AM   #1 (permalink)
Toyota Lover
KerTiZ's Avatar
View KerTiZ's Photo Gallery
I have a 00 Sienna and when i drive it on the highway, the front left side makes a loud sound and starts to vibrate once i hit over 140km/hr ... it goes back to normal once i go back down to ~130 or so.... does anyone know what the problem is? its been doing this since we bought it.
KerTiZ is offline   Reply With Quote
Old 08-30-2003, 05:29 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Well.....to fix the problem I'd start with cheap methods. Have you balanced the tires lately? You might try rotating them as well. Are you sure that the lug nuts are tight on that wheel?
I had a vibration in my jeep for the longest time and it turned out to be a bent front driveshaft.....damn rocks! It was causing my pinion to leak as well.
More information would be helpful also.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline   Reply With Quote
Old 08-30-2003, 07:33 PM   #3 (permalink)
Toyota Lover
KerTiZ's Avatar
the Tires have been rotated and it the problem still persists.. it only happens at high speeds.. and when i turn the wheel slightlt it seems to stop for a while.. but as soon as i am going straight.. the vibration returns... also.. it doesn'st really vibrate too much.. it SOUNDS lik the front is vibrating and it makes a loud humming sound.
Old 08-30-2003, 10:31 PM   #4 (permalink)
Listen Fatboy....
JeremyH's Avatar
Have you had it aligned??
I have seen vehicles from the factory that needed an alignment. Follow these steps to do a quick check of the alignment:
1) mark the tires (front and rear of wheel) with chalk at a set distance off the ground and at a specific point on the sidewall (i.e. a lip or something)
2) measure the distance between the two front marks on the tires
3) measure the distance between the two rear marks on the tires
These two distance (or "toe") should be almost the same....if the marks on the front of the tires are a little less (~1/8" or less) then you should be fine. This is called "toe in" as if your tires are pigeon toed as if seen looking from the back of the tire. If the distances are greatly off, then you should get the front end aligned.
Hope this helps.
