2000 Sienna brake light fuse blowing - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 02-24-2008, 09:23 PM   #1 (permalink)
View nec0's Photo Gallery
Hi,
I've got a 2000 sienna which has a malfunction in the brake lights; they don't work.
I've tried replacing the fuse, but it keeps blowing out???
What do you think the problem is?
Thanks
nec0 is offline   Reply With Quote
Old 02-25-2008, 06:55 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check the wiring for shorts. If the rear door has a brake light installed look where the wiring harness jumps from the chassis to the door. This area can take a lot of abuse from opening and closing the door.
Check the plugs for the bulbs plus the bulb itself. On rare occasions the filament in a bulb can fail causing a short to anther circuit.
If the car has a trailer hitch wiring harness also look there.
Old 02-25-2008, 06:59 PM   #3 (permalink)
ELL
ELL's Avatar
View ELL's Photo Gallery
If the fuse keeps blowing, check the wiring.
2000 Camry LE I4.
ELL is offline   Reply With Quote
Old 02-26-2008, 12:46 PM   #4 (permalink)
I found a slight pinch in the rear door brake light wire, but when i opened it up, it was fine.
Do you think it could also be the brake switch?
I also replaced the battery recently, so do you think that could also have something to do with it?
thanks again
