headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 03-13-2008, 12:51 AM   #1 (permalink)
View clamdigger's Photo Gallery
headlights
Hi, I have a 1998 toyota sienna van. The headlights come on
brite only, if I switch the brites to off then I have no headlights. when the blue lndicter light is off then I have
all my lights it comes and goes. When the lights are on
my right blinker light works but very fast if I turn of the
lights then it works just fine. I was hoping if some one
might have an idea.
clamdigger is offline   Reply With Quote
Old 03-13-2008, 02:57 AM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $903564
View humanoid's Photo Gallery
Do you have some sort of tow hitch on there? It may be wired incorrectly. It also sounds like you have a bad ground somewhere. Did you have some recent work done to it? How long has it been happening? Can your headlight problem be reproduced consistently?
This is my sig.
humanoid is offline   Reply With Quote
Old 03-13-2008, 11:55 AM   #3 (permalink)
No I have no hitch or work done. It started with the signel light and about to two weeks
ago the headlights started in and has been like that,with no change
Old 03-13-2008, 06:12 PM   #4 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
I would check the wiring of the signal lights to make sure they are not frayed or severed and acting as a bad ground causing your problems.
This is my sig.
Old 04-09-2008, 08:34 AM   #5 (permalink)
View Gramps 750's Photo Gallery
On the turn signals (this is going to sound strange)take the bulb out of the socket and look into the socket, you will see 2 silver tabs CAREFULLY with a tooth pick pull up on each tab so that they make a better contact to the bulb.
As far as your headlite problem I bet that both bulbs are bad on the low beam side. Common problem, what happens is 1 bulb goes and sends a power serge and blows the other. Pull the bulbs out and with a test lite check and see if you have power as you go back inforth from low beams to high beams.
Gramps 750 is offline   Reply With Quote
