Hello there, we had the same problem when our bulb when out. About two years passed and finally I just decided to give it a try and open it by myself. There are actually only three screws that you must remove. On is under the the dash on the drivers side, below the thing were the air comes out. The other two can be found by removing the panel where the cd player is. Next if you look under the section you will find the other two each. I dont know if you understand that..... Just put a light on top of youre cd player after you remove it. Anyways here is the sort of trick and scary part. You have to pull the dash out by the bottom, it is a little difficult because there are two sort of arms that reach out under the AC controls. Once you are able to pull that u simply just start pull out the dash by the sides....... give it a couple tugs. After that i would suggest disconnecting all the cables (clock, emergency lights, fog light, and pop out the light control)
Once that is off move youre steering wheel down and tilt the dash down to get it out to the way.
The intrument cluster is held by two or four screw I think
(I think 2)
Once there off flip the cluster and find the bulb.
The bulb i used was a 194 if or just pop out one of the bulbs that turn on when you open the door.. ( they are both the same
Thats basically how u do it
Sorry i have no camera for picks
The first time i did i it took me about 35 minutes
Now for the ac controls the light bulb needed is #2721
The big bulb for the speedometer is #194
Just do it yourself it will save you money. Let me know how it goes or if you have question.
GOOD LUCK
