2002 Siennna check engine - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 04-11-2008, 07:01 AM   #1 (permalink)
View ybjoe's Photo Gallery
Question 2002 Siennna check engine
About 2 weeks ago I put injection cleaner additive and couple of days later check engine light came on. Tighteed gas cap and a day later light disapered. 1-1/2 week later when gas tank was quarter light came on. Toped up gas and day later light disappered. Can someone advise what should I do or change. Thanks.
ybjoe is offline   Reply With Quote
Old 04-11-2008, 11:16 AM   #2 (permalink)
View tkevin07's Photo Gallery
couldl be bad gas cap, could be a number of different things, if u need to smog and the light is off u can fail still because the ECU has a temporary abnkk where it willdouble checkk a problem before setting the CEL get a code reader and read the code, even with the CEL off the code is still stored in there
tkevin07 is offline   Reply With Quote
Old 04-11-2008, 02:45 PM   #3 (permalink)
Thanks for the answer
Old 04-12-2008, 06:57 AM   #4 (permalink)
View Gramps 750's Photo Gallery
When you take the gas cap off look at where the cap screws on to the filler neck and see if there is any rust on the filler neck. If there is take some fine sand paper and remove the rust. Check the gasket on the cap also.
Gramps 750 is offline   Reply With Quote
Old 04-12-2008, 11:44 AM   #5 (permalink)
Thanks Gramps 750
