Please help. 1998 sienna won't start... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 04-22-2008, 08:53 PM   #1 (permalink)
View saung98sienna's Photo Gallery
I never had a since I installed a used engine recently. I just did and oil changed last then a week ago. this afternoon I drove over a railraod track pretty fast, didn't see the big bump. I did not hit anything but went hopped pretty high went I went over the bump. Ater I went over the bump I felt the engine lost power, I gave gas, it wouldn't accelerate, the engine run very rough, the check engine light came on. I pulled over, looked under the van, no fluid leaking, not a sign of an scrape underneath the van. The did start up, ran very rough, put in drive it would just rolled. I had it towed home. I checked if I was getting fuel, fuel is ok. I took off the air box and tried to sstart the van, kept trying and trying then I see some white, mist of smoke coming out from the intake tube. Is my engine gone? Any advices would be really appreciated. thanks.
saung98sienna is offline   Reply With Quote
Old 06-17-2008, 12:11 AM   #2 (permalink)
View arturo's Photo Gallery
Hi maybe u should check ur battery terminals, i remember once ours didnt start up the terminals "looked" tight but were actually, slightly loose. Try tightening them.
arturo is offline   Reply With Quote
Old 06-17-2008, 12:35 AM   #3 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
If the check engine light came on, you should start there by retrieving the code. Your car is trying to tell you something.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
