Originally Posted by 05DCLB
Here in Ohio after 1 winter that bearing is seized in housing. Dont use heat, that will melt mount rubber. Did you drop front exh pipe for room to swing hammer?. Worst case is taking axle out with housing and pressing out.
Thank you for your input...
Here are my discoveries so far:
1. The bearing housing is part of the rear motor mount which can't be removed without raising the engine.
2. I have removed the exhaust system which gives me better access to the imtermediary shaft. However, it is still going to have to be either removed with a large slide hammer and a chain around the rear CV housing (conical shaped) OR...hammering it out via a large pipe placed against the CV housing.
A large pickle fork + 2 1/4" open may work also.
I can't believe a tool hasn't already been made to attach to the shaft and hydraulically force it out.
3. Any more ideas out there?, please.
