Trouble Code P0125 on 2000 Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 05-11-2008, 10:27 PM   #1 (permalink)
View lifesheba's Photo Gallery
My 2000 Sienna has 143K miles and is suffering code P0125. The Van drives fine other than the check engine light is on. I have done the following repairs but nothing helps.
1. Change Engine Coolant Temperature Sensor 89422-35010
2. Change No.2 ECT Switch 89428-30130
3. Check No.1 ECT Switch; works fine
4. Check Thermostat; works fine
5. Flush and change engine coolant/anti-freeze
I used to have P0155 and P0125 came up at the same time a while ago. I replaced O2 sensor (Bank2, sensor1). It was OK for a little while then the P0125 shown up. It was intermitten in the beginning when I drove with cold engine in the winter. It was fine if I warm up/idle the engine for 5-10 minutes then drove. Now it shows up everytime I drive; very consistent with no other code.
I disconnected the battery then idled the engine for ~15 minutes yesterday with the heater in full blast (both front & rear); driving around without triggering the check engine light. The code reader pulled P0150 with no other code. I erased the code and let the Van sit overnight.
I drive the Van again and P0125 shows up again. Erase it many times but it always come back right away. Your tips will be much appreciated.
Thanks,
lifesheba is offline   Reply With Quote
