Pcode 1155 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 05-26-2008, 12:14 AM   #1 (permalink)
View awakumr's Photo Gallery
Pcode 1155
My 2001 Sienna just popped up with a 1155 error code. It say A/F Sensor Heater Circit Malfunction. Which O2 sensor is it.
awakumr is offline   Reply With Quote
Old 05-28-2008, 11:30 PM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
P1155 is a heater circuit malfunction on bank 2, sensor 1. That'll be the sensor in the manifold closest to the front of the car or the radiator (the easy one to get to).
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 05-30-2008, 06:24 PM   #3 (permalink)
Thanks, I already got one on order to replace. I'll let you know how it goes.
Old 05-30-2008, 10:34 PM   #4 (permalink)
Qslim's Avatar
Do yourself a favor and spray the sensor down with some penetrating fluid or the like and let it soak in for several hours before you replace it. That will make sure the sensor doesn't seize in the manifold and ruin the threads.
-- Get him, boy....
Old 05-31-2008, 09:30 PM   #5 (permalink)
Recieved the sensor via USPS today at 2:00pm. Van up and running by 2:15pm. I used the anti-seize compound that came with the sensor. I ordered it from OxygenSensors.com for $170. The local toyota dealer wanted $253 for the sensor. Qlsim, thanks for your support.
Old 06-01-2008, 07:39 PM   #6 (permalink)
View camlex's Photo Gallery
from toyota, internet price was $110
camlex is offline   Reply With Quote
Old 01-18-2010, 08:18 AM   #7 (permalink)
View npcomplete's Photo Gallery
I have exact same code 1155, do you remember the part number?
npcomplete is offline   Reply With Quote
Old 01-19-2010, 05:10 PM   #8 (permalink)
View sma10's Photo Gallery
Would appreciate if you could give the part #?
Here is some confusion with my Sienna 2000 XLE check engine light
I had P1135 code Bank 1 Sensor 1. Called Toyota dealer and they send me Air Fuel Ratio Sensor part # 89467-41011. After replacing the sensor the car again got a check engine light now with 1555 code(Bank 2 Sensor 1). However when I called another dealer he mentioned me that in case of B2S1 you would need the 89467-41011 and the part that is actually for B1S1 is 89467-41021.. My Question is there any difference between these 2 parts?
Also if you give the details on the part # It will be of great help to me...
Thanking in anticipation.
sma10 is offline   Reply With Quote
Old 01-21-2010, 08:40 PM   #9 (permalink)
View sam_wynn's Photo Gallery
B1S1 OR B2S1 are both A/F sensors. The only difference is the wire length.
sam_wynn is offline   Reply With Quote
