2002 Sienna Keyless Entry, Power Door Locks, and Dome Lights won't work. - Toyota Nation Forum : Toyota Car and Truck Forums
Wheel & Tire Center
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 07-29-2008, 09:24 AM   #1 (permalink)
View Sytec's Photo Gallery
All of a sudden the Keyless Entry, Power Door Locks, and Dome Lights on my 2002 Sienna won't work. I have checked EVERY fuse both under the dash and under the hood and all look good. My daytime running lights, power sliding door and power mirrors all work fine. Is there a control module or something that controls those three things that could have gone bad?
Thanks
Sytec is offline   Reply With Quote Quick reply to this message
Old 07-30-2008, 02:04 PM   #2 (permalink)
View Krichau's Photo Gallery
The same thing just happened to our 2004 Sienna.
The fuse under the hood was blown for our dome lights, so I replaced it and then I could immediately smell a hot electrical odor coming from under the dash. I pulled the fuse out and then today we noticed that the key fobs would no longer lock\unlock the doors. Plus, now the light on the dash is illuminated showing that a door is ajar.
Krichau is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 06:02 PM   #3 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Thanks
Look for a 25A fuse labeled 'door', it looks like it encompasses all the items you mentioned. These mini fuses can look deceptively good, I've been tricked quite a few times with a cursory inspection. The only way to check a fuse for sure is to test continuity with a meter.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote Quick reply to this message
Old 09-27-2008, 04:39 PM   #4 (permalink)
View racingoklahoma's Photo Gallery
did you get your van fixed my has done the same thing
racingoklahoma is offline   Reply With Quote Quick reply to this message
Old 09-27-2008, 04:40 PM   #5 (permalink)
I also have had the same problem with the power door locks changed the fuse as you said no luck is thier another way to check or replace fuse? thanks
Old 09-28-2008, 12:52 PM   #6 (permalink)
Unfortunately, no. I have just been living with it since there is nothing critical broken. I you find out anything, please let me know.
Thanks,
Pat
Old 09-28-2008, 12:55 PM   #7 (permalink)
Qslim,
Thanks to your reply to my post. Sorry that it has taken me so long to do so. I am 99.99% sure that it is not the actual fuse as I have replaced it multiple times with multiple brand new fuses (all of which work in other locations).
Thanks again,
Pat
Old 09-28-2008, 04:20 PM   #8 (permalink)
Racingoklahoma,
No, none of these ideas fixed our van. The local Toyota dealer replaced the ECM the other day and everything works fine again. However, it did take countless hours of troubleshooting b4 Toyota figured it out. This really surprised me.
Old 09-29-2008, 08:02 PM   #9 (permalink)
Originally Posted by Krichau View Post
Racingoklahoma,
Old 09-29-2008, 08:05 PM   #10 (permalink)
I have pulled every fuse in the //// , replaced the door fuse with a new one with no luck. what was the cost ECU and is it behide the glove box? Thanks for all the Help.
Old 09-29-2008, 10:34 PM   #11 (permalink)
Qslim's Avatar
Qslim,
Thanks again,
Pat
Well, that's a shame. Have you taken it to a dealer or another qualified tech with access to toyota's info? Electrical problems can be hard to diagnose, and even harder over the internet.
-- Get him, boy....
Old 09-30-2008, 06:19 AM   #12 (permalink)
Racingoklahoma,
I really don't know where this particular ECM is located.
I ended up with about $500 in our ECM replacement. The ECM was about $250 and the rest was labor.
Sorry that I don't have the specifics, but hopefully this helps.
Old 10-02-2008, 07:30 PM   #13 (permalink)
Racingoklahoma,
Old 10-02-2008, 07:31 PM   #14 (permalink)
Thanks again for the help. I will try and find where it is check the number there have been afew on ebay for 120.00 or so, thanks Bill
Old 01-23-2009, 01:04 PM   #15 (permalink)
I have finally fixed my problem thanks to information from another thread listed below:
door locks and interior lights don't work
As a review, all of a sudden the Keyless Entry, Power Door Locks, Dome Lights and all courtesy lights on my 2002 Sienna would not work. I solved the problem by replacing the COMPUTER, MULTIPLEX NETWORK BODY that it turns out controls all of these things. It is a gray 5.5"x2.5"x1.75" plastic box that is plugged into the the back (or top) of the fuse box that is located by the driver's left knee. You have to take the lower bezel of the dash off to get to it. Door threshold has also to be un-clipped, I also took the hood popping handle off, around 6-7 screws in total, it takes about 30 min to take the relay off and put it back again and close everything off.
On the box I found these following numbers imprinted on it:
COMPUTER, MULTIPLEX
NETWORK BODY
TOYOTA
89221-08010
241000-0190
Fujitsu Ten corp. of America USA
There is also a paper sticker on the back:
VRI0190C
010728A0063
ASSEMBLED IN USA
I found one used on Ebay for $75.00. The cheapest I could find a new one for was $328.00 at
http://www.toyotapart.com/product.asp?pID=136997&cID=1 .
I'm glad I got the used one because some of the information that I read suggested that a new one might have to be programmed.
Good Luck
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
