2001 Sienna Bumper Repair... need some help - Toyota Nation Forum : Toyota Car and Truck Forums
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
post #1 of 2 Old 04-11-2010, 11:13 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi all,
I have a little dent in my front bumper and was planning on taking it off, and trying to bang it out but I'm having some troubles removing the bumper cover. I have detached all screws and bolts except for the ones that are located directly under the grille, so I thought I needed to remove the grille as well, and I have popped the pins on the top of the grille (cowl pins?) but there's something else holding this inplace... since I have already broken a few of the pins, I'm nervous about breaking the grille. Does anyone have any good instructions on how to remove the front bumper cover (possibly the grille too).
Here's a photo of the damage and work in progress...
woops... where'd the picture go?
Trying again...
TheRooster1968 is offline
post #2 of 2 Old 04-27-2010, 01:10 AM
Quoted: 0 Post(s)
There are three snap connects holding the grille in place (one in the middle as about 8" away from the middle on each side) as well as one on each end (left and right sides). I used a small flat head screwdriver to push on the connectors to loosen them.
It also helps if you remove the corner lights to access the end connectors. Remove the screw at the top and gently pull the light forward.
To push out the bumper cover, remove it from the van and use your knee to push it back out. I just did this yesterday. Luckily it appears that you don't have much damage.
Hawaiiage is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
Gear in this thread - Powered by O'Reilly Auto Parts
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
