Sounds like you plan on changing the brake pads yourself. At the retail auto stores they have 3 common flavors - cheap, silver, gold, and (4th) specialty pads.
For pure stopping performance, the silver or gold will work fine. Since the van is heavier (~4200 lbs), the gold rated pads vary and can come in both semi-metallic or ceramic, it all depends on which auto store. Semi-metallics have the best stopping performance followed very closely by the ceramics. The difference is small and negligible. Note that the composition of the pad materials vary among all pads (semi-metallic and ceramic).
I would pick the semi-metallic since they offer the best overall stopping performance without analyzing what each pad is composed of (i.e. hours of research) .... in other words, you cannot go wrong with the semi-metallic pad.
I like Autozone since they have a generous lifetime policy. Advance Auto has the same policy but I have never purchased the pads there so I don't have first hand experience.
Other factors that may or may not be important to your
- dust
- rotor life
- $20 (silver) vs $35 (gold)
Reason: ditto
