03 starts then dies - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 02-17-2011, 06:39 PM   #1 (permalink)
View SmellyCat's Photo Gallery
03 starts then dies
Hello all! Ive had Toyovans and 2 Previa's. I have a 03 Sienna now!. Great van. Today... it starts and dies. if I press the pedal it will run. Let off the pedal it dies. Anybody got a answer? It seems weird to drive great one day .. today act up. SC
SmellyCat is offline   Reply With Quote
Old 02-17-2011, 07:14 PM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
^so you're saying if you keep giving it gas it will stay running, and if you let off, it automatically dies?
I had this issue in my 2000 Maxima, manual transmission. As long as I kept revving it, it would run. The second I would push in the clutch, it would die. It turned out to be the MAF (mass air flow) sensor. Another guess, IAC (idle air control) valve.
By the way....Welcome to TN!
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 02-17-2011, 07:26 PM   #3 (permalink)
View wiswind's Photo Gallery
I'm voting for the Idle Air Control valve in the throttle body.
In this picture, from my 2003 Sienna, the right hand throttle body, closest to the passenger compartment has a small hole in the bottom.
This is the air passage INTO the Idle Air Control valve......spray some fuel injector cleaner into this hole to clean out the IAC.
I vote for this because it is a very likely cause of the problem....and the easiest/cheapest to try.
wiswind is offline   Reply With Quote
The Following User Says Thank You to wiswind For This Useful Post:
LPNBALC (10-14-2011)
Old 02-17-2011, 10:23 PM   #4 (permalink)
View Black Sunshine's Photo Gallery
I'd check the IAC, then the MAF, and possibly the throttle position sensor(TPS).
Black Sunshine is offline   Reply With Quote
Old 02-18-2011, 05:02 PM   #5 (permalink)
Wow. how cool and easy. unhooked all the unhookies. sprayed away, then dripped some oil in it for good luck. Ran like a yugo for about 20 seconds and kept on running Waaaawhooo! Thanks everyone. I was dreading this weekend. SC
Old 09-27-2011, 05:04 PM   #6 (permalink)
View wisconsinguy's Photo Gallery
Toyota Sienna Starts and Stops Dies
2001 Toyota Sienna would start and die and stop. Printed out the IAC (Idle Air Control) information from the website and took it to my mechanic. $60 later, Toyota Sienna start and die and stop problem was solved by cleaning the carbon.
wisconsinguy is offline   Reply With Quote
Old 12-27-2011, 11:31 PM   #7 (permalink)
View zumvoll's Photo Gallery
My 01 Sienna was doing the same thing and I followed WisWind's guidance above about the Idle Air Control Valve. When I finally got it off, it was completely caked with carbon. A little carb cleaner and a tooth brush later and It was shinny and clean. After reassembling, the Van started on the first try like a NEW van and has been running GREAT. That was definately the problem!!!! Thanks WisWind!
zumvoll is offline   Reply With Quote
Old 03-23-2012, 08:00 PM   #8 (permalink)
Sienna Daddy
View bleevernHim's Photo Gallery
Ok I went to the autoparts store to buy the fuel injector spray but only found the type you pour in your gas tank during a fill up. They said I would need carb cleaner, and a MAF sensor cleaner.
In the end I purchased carb cleaner, MAF sensor cleaner, throttle body/ air intake cleaner and some fresh rags.
What should I do? No fuel injector spray. Should I just clean the TB as zumvoll said in the last post? I want to do this tomorrow before the rain comes.
Help? Thanks
bleevernHim is offline   Reply With Quote
