Towing a Pop Up Trailer With a 2002 Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 03-06-2011, 11:15 PM   #1 (permalink)
View dp7676's Photo Gallery
I want to rent a pop up trailer and pull it with my 2002 CE Sienna. I found the old sticker and it says it came with the towing package. What does that mean? I don't have a hitch for it. I need to get one installed. Can anybody give me any reccomendations? The trailer can either weigh 2700 lbs or 2200 lbs depending on which one I rent. I need to pull it approx. 190 miles round trip. What kind of hitch do I need to get installed? They also say that I need a 7 point wire harnass to hook up to the trailer which has electric brakes. Any advice would be great. Thanks.
dp7676 is offline   Reply With Quote
Old 03-07-2011, 08:27 PM   #2 (permalink)
View SiennaDriver's Photo Gallery
We have a 10' when closed 1970 pop top trailer and have taken it from PEI to the Great Lakes to Virginia over the years and never had a problem with our 2000 Sienna LE. It came with the towing package standard, you might want to check if the CE came with it. I think, but could be wrong, that dual fans at the radiator and a transmission cooler set it apart.
The tow bar easily bolts on in place of the tow hooks on the back. Lights connect inside the storage area where the jack is. Handling is unremarkable.... it tows incredibly well.
One caveat is to have the proper weight at the ball connection. We once thought we could carry some stuff which primarily added weight to the back of the trailer; the trailer swayed significantly at speeds above 40. Transferred that weight to a roof turtle shell container and all was well.
We've had a great time with our trailer camping 5 weeks every summer. Enjoy it!
But with electric brakes, you're probably looking at a much larger trailer. So for that you're on your own.
SiennaDriver is offline   Reply With Quote
Old 03-08-2011, 08:26 PM   #3 (permalink)
View wiswind's Photo Gallery
I got a Curt Class III hitch for my 2003 Sienna.
A bunch of the hitch manufacturer's are all owned by 1 of them.
A class III has a 2" receiver and is the more heavy duty version.....very close in price to the lighter capacity Class II that has the smaller receiver.
I had a local hitch shop order and install the unit and the wiring for the lights.
They can also take care of the brake controller.
A good hitch shop can guide you through the process and do a good installation.
My 2003 did not come with the towing package.
The towing package comes with a auxillary motor oil cooler that is at the oil filter location.
Coolant flows through a small "sandwich" heat exchanger at the base of the oil filter.
The towing package also comes with an auxillary transmission fluid cooler.
The location of the factory (towing package) auxillary transmission fluid cooler is inside the front, driver's side, fender.....ahead of the front tire.
There will be lines going there from the transmission and the standard transmission cooler that is mounted in the base of the radiator.
I installed a auxillary transmission cooler in front of the radiator.
Link to the first in a series of pictures that show this.
http://rides.webshots.com/photo/2417...11220610HeZCdx
Dual electric fans are standard on all 1st generation Sienna.
HOWEVER, towing package or no towing package may determine what fans are used and it DOES change the radiator cooling fan "logic" (when the computer turns the fans on and off).
In stop and go traffic, I keep the A/C on (defrost will do the same) as this keeps the radiator fans ON more, which will keep your transmission fluid much cooler.
I installed Airlift Air Bags inside the rear coil springs.
These do NOT increase the rated towing capacity of the suspension or vehicle.
They DO help to maintain the correct height of the rear of the vehicle under different loading conditions.
If you measure the normal height of the hitch from the ground without the trailer and luggage in the vehicle.......then measure the height once loaded, you then add air to the air bags (up to the maximum of 35 lbs) to restore the vehicle height to the normal level.
This helps the vehicle handle and ride better when loaded.
You don't need a air compressor for them (although they sell one) a simple bicycle pump is all that is needed to adjust the air pressure.
If you click on this picture, it will take you to the first in a series of pictures that show the installation of the bags and the routing of the air tubing.
I have the air tubing go up into the jack compartment.....and the bicycle pump connects to a tire type of air valve at that location to adjust the air pressure (routing and location shown in my pictures).
When figuring your towing capacity, there is a tongue weight.....the weight that is pressing DOWN on the hitch, and a trailer weight......the weight of the trailer INCLUDING anything in it.
THEN there is the total weight......the weight of the trailer (including everything in it) your luggage inside (and on) your vehicle......including all the people inside the vehicle.
Read up, learn......ask the shop that installs your hitch for pointers on towing.....well in advance of leaving for your trip.
wiswind is offline   Reply With Quote
Old 04-07-2011, 01:36 AM   #4 (permalink)
View ironbender's Photo Gallery
Additionally, you will need an electronic brake controller inside your van. This will send the voltage to the trailer brake when you apply the vehicle brake.
We have an '01 Sienna and I would look for a smaller/lighter popup that would still fit your needs. I think the Sienna is "rated" to tow 3500#, but for me, I'd stay below 2K.
U-Haul is usually a pretty good place for hitch and installation. When I checked with the local U-Haul, I was surprised at how reasonable their price was (can't remember now). Make sure they have the hitch in stock well in advance of your trip. They may have to order it.
--Mike
ironbender is offline   Reply With Quote
