"deodorizer" smell when heat on - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 03-16-2011, 07:46 AM   #1 (permalink)
View KM,NC's Photo Gallery
I know this sounds strange - my husband thinks I'm crazy but that's besides the point - however it started yesterday that when I turn on the heat, it eventually smells like a deodorizer.
I realize it could be worse! However I'm allergic to perfumy smells and I either run the heat with the rear windows cracked or just not at all.
I thought maybe one of the kids left their little ball deoderizer that you put in shoes in the van and it rolled up to the vent under front seat but not the case.
Any suggestions other than a psychiatrist.
KM,NC is offline   Reply With Quote
Old 03-16-2011, 11:10 PM   #2 (permalink)
View Black Sunshine's Photo Gallery
That is interesting. Some of us would like to know how you accomplished this problem. Somewhere up front there is a place that the heater fan draws air in. This place may be your problem.
Have you tried switching it to draw heat from outside. Does it have a change when you switch it from outside to inside? Does it change when you switch it from upper vents to floor vents? If the smell is always there it's probably from the actual fan area.
Did it smell badly before? There is a deodorizer that can be sprayed into the vent system. Could this have been recently put into yours?
Black Sunshine is offline   Reply With Quote
Old 03-17-2011, 08:40 AM   #3 (permalink)
LOL!!! Yes, this IS a serious problem that no one else should have to face. If I can save just one life, it's worth it.
This morning it didn't do it (last 2 mornings yes).
I DID have my car detailed about 2 weeks ago, so I'll stop by and ask, however strange it was such a delay.
If it does it again I'll also try to switch from outside/inside air.
Thanks I'll keep you posted . . . I'm sure you all will be on pins & needles.
Old 03-23-2011, 03:04 AM   #4 (permalink)
View 1bosshog2's Photo Gallery
If it's a sweet smell it could be antifreeze. Which means your heater core could be leaking. If you turn on the defrost does the windshield fog up or does the defrost seem to work ok? Also look for steam coming out of the vents when the defrost is on. My wife's expedition{not related to this board-our problems with our sienna our much worse at the moment} is currently experiencing this problem.
1bosshog2 is offline   Reply With Quote
