All Power Windows Stopped Working at Once - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 03-18-2011, 03:33 PM   #1 (permalink)
View SiennaAVL's Photo Gallery
I took off the driver door inside panel and unhooked the harness for the windows and door lock. When I reconnected it, there was an odd noise, and the passenger window went down a few inches when I pushed that button on the driver door, then nothing. Both sides don't work from the driver door, passenger door switch doesn't work, and switch on center console doesn't work for the rear panel windows, they're all dead. The fuse is good, so is the one that I used to replace the good one.
I'm sure it's a relay somewhere, but where? What part number and where is it? I looked under the steering wheel, but can't find anything.
Thanks for the help.
SiennaAVL is offline   Reply With Quote
Old 03-18-2011, 09:04 PM   #2 (permalink)
View Black Sunshine's Photo Gallery
There is a large panel under the hood that is primarily relays. It is between the battery and the brake fluid reservoir. It has a diagram listing what they all are.
Black Sunshine is offline   Reply With Quote
Old 03-19-2011, 11:56 AM   #3 (permalink)
Thanks, still not sure which one it is?? I found a good link though, but still not sure which relay controls the power windows based on the limited labeling.
http://minivanclub.org.ua/info/Sienn...%20-%20EWD.htm
Anyone?
