All brake lights dead - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 03-25-2011, 05:25 PM   #1 (permalink)
View Beaver's Photo Gallery
The lamps are good but no lights illuminate when I apply the brake. I looked for a fuse in the engine compartment fuse boxes and found none labeled as brakes. Tested all of them just in case.
Is there a brake relay or fuse somewhere else in the van that could be cooked?
'02 Sienna CE 219,000km and rising.
'98 Corolla CE 295,000km and rising.
Beaver is offline   Reply With Quote
Old 03-25-2011, 06:35 PM   #2 (permalink)
View wiswind's Photo Gallery
In my 2003.......
There is a 15amp fuse labeled "stop".
This fuse is located in the fuse panel in the passenger compartment....driver's side.
There are 5 columns of fuses, in the 2nd column from the left, 2nd fuse from bottom.
The lamps are turned on/off by a switch that is up under the dashboard.
I think that it will be located someplace on the shaft that connects to the brake pedal.
I have not looked at it, but the location diagram on Alldata seems to have it in that area, and states that it is inside the passenger compartment.
wiswind is offline   Reply With Quote
The Following User Says Thank You to wiswind For This Useful Post:
Beaver (03-25-2011)
Old 03-25-2011, 11:03 PM   #3 (permalink)
Thanks, found the fuse panel behind the little coin pocket. replaced the blown fuse and I have brake lights. Kinda wonder what made it blow though.
Old 03-27-2011, 06:34 PM   #4 (permalink)
View Black Sunshine's Photo Gallery
I hate how you have to take bolts out of the dash to get to that fuse panel.
Black Sunshine is offline   Reply With Quote
