From here:
http://minivanclub.org.ua/info/Sienn...mci/047srs.pdf
but still can't tell if the airbag is nonoperational for the passenger side when that light is flashing.
The SRS is a driver and front passenger protection device which has a supplemental role to the seat belts.
When the ignition SW is turned to ACC or ON, current from the CIG fuse flows to TERMINAL (A) 6 of the center airbag
sensor assembly. Only when the ignition SW is on does the current flow from the IGN fuse to TERMINAL (A) 5 of the center airbag sensor assembly.
If an accident occurs while driving, when the frontal impact exceeds a set level, current from the CIG or IGN fuse flows to
TERMINALS (A) 14, (A) 10, (B) 2 and (C) 5 of the center airbag sensor assembly to TERMINALS 1 of the airbag squibs and the pretensioners to TERMINALS 2 to TERMINALS (A) 13, (A) 11, (B) 1 and (C) 6 of the center airbag sensor assembly to TERMINAL (A) 27, (A) 28 or BODY GROUND to GROUND, so that current flows to the front airbag squibs and the pretensioners and causes them to operate.
When the side impact also exceeds a set level, current from the CIG or IGN fuse flows to TERMINALS (B) 5, (C) 2, (B) 2 and (C) 5 of the center airbag sensor assembly to TERMINALS 1 of the side airbag squibs and the pretensioners to TERMINALS 2 to TERMINALS (B) 6, (C) 1, (B) 1 and (C) 6 of the center airbag sensor assembly to TERMINAL (A) 27, (A) 28 or BODY GROUND to GROUND, causing side airbag squibs and the pretensioners to operate.
The airbag stored inside the steering wheel pad is instantaneously expanded to soften the shock to the driver.
The airbag stored inside the passenger’s instrument panel is instantaneously expanded to soften the shock to the front
passenger.
Side airbags are instantaneously expanded to soften the shock of side to the driver and front passenger.
The pretensioners make sure of the seat belt restrainability.
