You might try a subscription to alldatadiy.
They have electrical diagrams there.
For my 2003, the EFI fuse goes to the contacts of the EFI relay.......and a branch goes to the ECM (computer) BEFORE the relay.
The fuel injectors get power all the time at 1 lead, and the ECM provides a momentary ground path to energize the injector to spray the fuel.
You might pull the EFI relay out.....and see if the fuse still blows......would eliminate that ECM connecton (pin A).
Not likely that connection, but something past the EFI relay contacts.
Beyond the EFI contacts.....it goes a LOT of places......which is why I recommend the Alldatadiy subscription, so that you can follow the diagram for the 1998.
