If it is HOT outside, once you cool down the interior....you can switch the air source to recirculate to recirculate the cooler air inside the vehicle.
Starting with cooler air moving over the cold evaporator coil, you get more cooling effect from the A/C.
Also, keeping the front of the radiator mounted condensor coils clean will help.
Other than that, you would need to have the system checked out by a good technician to see if the system is cooling to specifications.
