Completed Projector Retrofit - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 06-11-2011, 01:21 PM   #1 (permalink)
View LUVLEXUS101's Photo Gallery
Just completed a Morimoto Mini H1 projector retrofit on my parents 2002 Sienna, figured I'd post up to give you guys some ideas. In comparison to stock light output these projectors blow the halogens lamps out of the water.
Here are a couple of pics for now till I get better shots. The projectors were more or less plug and play due to the lock nut and 9003 adapter plate that comes with the projectors. The projectors, bulbs, and relay harness were purchased at www.theretrofitsource.com.
Ballast and relay harness mounted
LUVLEXUS101 is offline   Reply With Quote
Old 07-04-2011, 10:46 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $447745
View uibalnme's Photo Gallery
Very Nice!
Looks like my gen3.5 Camry isn't going to be the only vehicle I have with a bi-xenon retrofit.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 07-04-2011, 11:05 PM   #3 (permalink)
Originally Posted by uibalnme View Post
Very Nice!
I believe the 01-02's came clear lens.
I found aftermarket lamps really cheap on ebay before:
http://cgi.ebay.com/ebaymotors/Toyot...ht_2432wt_1165
I'd recommend getting the relay harness from www.theretrofitsource.com and I cut the DRL wire from the module under the dash.
Old 07-04-2011, 11:16 PM   #4 (permalink)
uibalnme's Avatar
Yeah, I was just looking at those lamps. Buying the relay harness is a good idea, but I can make a set for much less than what TRS is charging for one. I also don't have to worry with DRLs. My 98 doesn't have them. I may do the retrofit after I complete my Mustang.
Old 07-05-2011, 06:26 PM   #5 (permalink)
Truth. Picked mine up for just 10 dollars when they were on sale.
Old 07-09-2011, 09:02 PM   #6 (permalink)
View Black Sunshine's Photo Gallery
Are those lenses plastic? Mine are glass. How hard was the fabrication?
Black Sunshine is offline   Reply With Quote
Old 07-10-2011, 10:11 PM   #7 (permalink)
Mine were plastic. Install is simple with the threaded back.
Old 07-13-2011, 11:14 AM   #8 (permalink)
Does these install without separating the lenses from the reflector?
