Question about MAF sensor in a 2000 Sienna
Recently had the master cylinder replaced at the corner garage. It's a single man shop, the kind of place one can hang and chat with the mechanic. Shortly after the master cylinder was replaced, the CEL light came on showing P0100 and P0110. I don't know if there's a connection between what the mechanic did and the trouble code, but he had that area torn apart.
He checked the connection and it looked good. Light was reset.
When the light reappeared, he removed the sensor and used some MAF spray cleaner on it, but saw he hesitated when installing it. Light was reset.
Regardless, the light is back on again and he's suggesting to replace the MAF sensor for some $200. I took it apart and all looks well. Reassembled and light remains on.
The part looks like an airplane engine, with an open end. Is it possible to install it either way.... and if so does it go with the open end towards the air cleaner, or the closed end towards the air cleaner. It was installed with the open end facing the air cleaner.
Suggestions?
