Won't Start Its not the Battery/Starter/Reley HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 08-03-2011, 06:34 AM   #1 (permalink)
View ginotoy's Photo Gallery
1998 toyota sienna won't start. Key turns, nothing happens. Has lights. We have checked the the battery, starter and relay all are working. Please help.
ginotoy is offline   Reply With Quote
Old 08-03-2011, 08:34 AM   #2 (permalink)
View SiennaDriver's Photo Gallery
Broken ignition switch or disconnected wire.
How'd you test the starter and relay, and did you check the battery with a load?
SiennaDriver is offline   Reply With Quote
The Following User Says Thank You to SiennaDriver For This Useful Post:
ginotoy (08-03-2011)
Old 08-03-2011, 01:52 PM   #3 (permalink)
Thanks. Is there a way of testing the ignition switch to see if its good? We took the starter and relay to O'Reilly and they tested them for us. Battery has not been tested with a load but all lights and radio work when key is turned. It is fairly new.
Thanks for your help, been unable to drive to a week.
Old 08-06-2011, 06:50 PM   #4 (permalink)
View Black Sunshine's Photo Gallery
Is your van one with a radio key? Perhaps there is something wrong with that system. If it's one of the newer style large keys it has a radio chip thing in it.
Black Sunshine is offline   Reply With Quote
Old 08-28-2011, 11:53 PM   #5 (permalink)
View ToyoGuard's Photo Gallery
Try Jump Starting It. When you put your negative cable on, find a ground somewhere on the engine not on the battery. See if it starts
ToyoGuard is offline   Reply With Quote
Old 08-29-2011, 06:20 AM   #6 (permalink)
View bill_toyota's Photo Gallery
Wait, how did you take the starter and relay to be tested? You took out of the car? Also, just because there is lights doesn't mean the battery isn't bad.
bill_toyota is offline   Reply With Quote
Old 09-20-2011, 07:57 PM   #7 (permalink)
View pbarnrob's Photo Gallery
Also makes me think of the Neutral Interlock on the transmission; if you aren't in either Park or Neutral, the starter won't engage (which if found useful on an older stick-shift once, to move a few inches, but now must be a no-no.)
It's embarrassing when you realize that's what it was, but better than $$$ repairs!
pbarnrob is offline   Reply With Quote
