Originally Posted by ToyoGuard
Replace the wheel hub bearing. It's about $150 bucks. You cant glue it back on, it wouldn't work properly. That hub bearing has the ABS sensor built into it. Once it's diconnected the way your's is, it's toast and needs replacing. Your light should shut off after you replace it
After cleaning the part up, straightening the few bent pins with a magnifying lens and spraying everything with electrical cleaner, I prepped the axle a bit (not really much to do with all that rust) and "primed" the part of the bearing assembly this part contacts with thinned epoxy glue. When that set, I applied JB Weld on the outer perimeter of the flange of the part that fell off and pressed it into place where it fell out of. After that set, I went around the perimeter with a second layer of JB Weld just to fill in any gaps I couldn't see which might let water or dirt in.
A soldering brush (like for plumbing) was an ideal tool for smearing adhesives.
It works great! Saved hundreds by salvaging the part, too.
Aftermarket axle bearings are about $150, the OEM is $400. After a lot of problems with aftermarket parts, I'm willing to pay the premium for the OEM.
Something caused it to fall off and it just might do that again. Time will tell, but for now it's a pleasure to have the ABS back and the dash lights out.
