Here is a quick write up on how to remove the spark plug tube gaskets.
Do one side at a time so have a reference for which way they go back in.
1. Clean Your Parts
This makes it a lot easier. I take a load of parts at once to be cleaned. They are cheap, easy and do a great job.
2. Bend Back Tabs
There are small tabs help hold the gasket in. Using a flat head screwdriver bend then back a little bit.
3. Remove Inter Gasket
The gasket will break apart but that is ok. Remove the inter part so you can get leverage under the gasket. There is wire inside, just pull enough out to get under the gasket.
4. Remove The Gasket
Now you can get you screw diver down under and pop it out. It did not take much pressure to pop it out.
