No need to jack the car because everything is within easy (well, sorta easy) reach.
Looking at the rear wheel assembly from under the car, near the lower shock mount, there's a wire that plugs into the ABS/TP sensor. It has a rubber boot on it, which might fail to do its job and let water in. Carefully unplug it and look for clean contacts on both ends - on the wire end and on the sensor end. I reached up with a camera and took some pics of the connector on the sensor end because that's a lot easier to look at. The wire end was easy. You might also check that the assembly (I posted a pic in my thread on the subject) is securely glued in place. Mine wasn't, and I fixed that by brushing JBWeld with a new plumbing soldering brush. That brush was perfect for smearing the stuff where it was needed. We've gone about 3500 miles with the fixed sensor, so I assume it's OK. Originally, it had fallen off the axle and was dangling on the car held to the car only by the wires.
The spray I used was just common electrical contact cleaner. I got mine at an online electronics store, but Radio Shack and places like that likely have it too. I think I once saw it at Walmart, in the auto section amongst the spray chemicals. We also use that stuff, it's like pixie dust, on our trailer wiring connector -- it looks fine but simply fails to work sometimes and that spray fixes it every time.
One thing you might want to look for On the schematic it appears the wire leading to the sensor has another connection somewhere, maybe under the car and it looks like the wires feed into a larger cable. You might want to follow the wire and see where it goes. But on that one I'm not sure as I never found it, and it might be a wild chase.
Good luck!
