Need help with spark plug tube gasket. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 09-14-2011, 10:01 AM   #1 (permalink)
jared_801's Avatar
View jared_801's Photo Gallery
I have a torn spark plug tube gasket. These gaskets are on the cylinder head cover and sandwiched between two plates. It appears the plate can not be removed. It looks like it is riveted on, or it's a bolt with a round head. How do you change the spark plug tube gaskets?
1992 Toyota 4Runner
1992 Toyota MR2 Turbo (sold)
2001 Toyota Sienna XLE
jared_801 is offline   Reply With Quote
Old 09-15-2011, 02:08 AM   #2 (permalink)
View ToyoGuard's Photo Gallery
You mean the tube seals on the valve cover. Is it right under the spark plug wire? Show me a pic if you have
ToyoGuard is offline   Reply With Quote
Old 09-15-2011, 10:00 AM   #3 (permalink)
jared_801's Avatar
On the top of the image you can see the underside of the valve cover. The 3 holes have have the spark plug tube gasket. I've been told you can use a large socket and hammer to just punch them out. The new gaskets are not very flexible. I tired pulling one out with a screw driver and it tore.
I've sent the parts off to be cleaned so and will get them back tonight. I hope to have a better picture then.
1992 Toyota 4Runner
Old 09-15-2011, 10:47 AM   #4 (permalink)
Oh ok, Yeah those are the tube seals with the valve cover. Normally these seals need a little persuasion to get them out. You can use the method you said by driving them out or a screwdriver, but you can also go to your autoparts and buy a $10 seal puller that will work even better
The Following 2 Users Say Thank You to ToyoGuard For This Useful Post:
jared_801 (09-15-2011), Sienna2002 (10-10-2011)
Old 09-15-2011, 04:53 PM   #5 (permalink)
View wiswind's Photo Gallery
There is a tab on each one......on the inside.
You can sort of see one of the tabs in this picture, left side of the left most seal.
You can bend the tabs slightly to be able to remove each seal.
Install the new seal in the same orientation as the old one, and then tap the tab back into position.
A small screw driver should be able to help in bending the tabs.
wiswind is offline   Reply With Quote
The Following User Says Thank You to wiswind For This Useful Post:
