Low voltage causes all sorts of instrument panel anomalies which might explain what you're seeing. A failing charging system could also explain why the engine sputters and dies.
Cranky-Condor is right, you have to eliminate the battery as the source of the problem before proceeding. I had a battery fail after only one year so we can't automatically assume your battery is OK. In addition to what he suggested, here's a no-cost test you can try:
* after the van has been sitting (and not running) for a while, put a voltmeter across the battery terminals. Make a mental note of the voltage. If it isn't at least 12 volts, charge it.
* start the engine.
* now check the battery voltage again, with the engine running. You should get a reading of 13.8 volts or maybe even 14.0 volts.
If you don't see 13.8 volts or more across the battery with the engine running, you have an alternator/voltage regulator problem, which is usually fixed these days by just replacing the alternator. Post back and let us know what you found.
