Error Codes; PO171, PO174, PO1150, PO300 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 09-28-2011, 09:32 AM   #1 (permalink)
jared_801's Avatar
View jared_801's Photo Gallery
I've got a 2001 Toyota Sienna XLE. Just put in all new belts, and replaced the left (front) cylinder head. I got it running but it does not idle well and I've pulled the following codes:
I know what all the codes mean. I think I can hear a vacuum leak which would cause these errors. Next most likely suspect is the Mass Air Flow sensor (MAF). Anyone else come across this same issue?
1992 Toyota 4Runner
1992 Toyota MR2 Turbo (sold)
jared_801 is offline   Reply With Quote
Old 09-29-2011, 02:51 PM   #2 (permalink)
jared_801's Avatar
Well I've found a hose I forgot to put pack on. That fixed that vacuum leak. I cleared the coded then after a test drive P017 & P0174 came back on. I cleared them again and they came back on.
The van is running much better. Where should I start?
1992 Toyota 4Runner
